Do you have the model Home in multiple locations?
I think you will get these errors if you first had the generated models in the default ModelsBuilder location in ~/umbraco/models but then changed mode to SourceCodeManual and generated the models in the new location.
You'll then need to remove the original generated models from ~/umbraco/models folder.
I figured it out, my models prj was using Umbro 10.1.0 but my web project was still using the 10.1.0_rc, updating the web project fixed it, I must have missed it when I updated the other projects in the solution doh!
ModelsBuilder Issue? Ambiguos reference
I'm getting a strange Ambiguous reference isssue on some properties.
This is my Umbraco settings.
Any ideas as to what might be causing this?
Hi Huw
Homein multiple locations? I think you will get these errors if you first had the generated models in the default ModelsBuilder location in~/umbraco/modelsbut then changed mode toSourceCodeManualand generated the models in the new location.You'll then need to remove the original generated models from
~/umbraco/modelsfolder.I figured it out, my models prj was using Umbro 10.1.0 but my web project was still using the 10.1.0_rc, updating the web project fixed it, I must have missed it when I updated the other projects in the solution doh!
