Hey!
I'm play today a little bit with umbraco to learn it with c#.
After little start errors run the system now and i can work with that in Visual Studio.
But now i have try to create a new "partial view" for the navigation with the template code, but if i reload the page they print errors.
I understand the errors but i don't know what i can do for fix.
Errors:
"IPublishedContent" does not contain a definition for "content", and no accessible content extension method could be found that accepts an initial argument of type "IPublishedContent" (possibly missing a using directive or assembly reference).
@{ var selection = Model?.Content.Root().Children.Where(x => x.IsVisible(PublishedValueFallback)).ToArray(); }
"IPublishedContent" enthält keine Definition für "Content", und es konnte keine zugängliche Content-Erweiterungsmethode gefunden werden, die ein erstes Argument vom Typ "IPublishedContent" akzeptiert (möglicherweise fehlt eine using-Direktive oder ein Assemblyverweis).
@if (selection?.Length > 0)
<ul>
@foreach (var item in selection)
<li class="@(item.IsAncestorOrSelf(Model?.Content) ? "current" : null)">
<a href="@item.Url(PublishedUrlProvider)">@item.Name</a>
</li>
</ul>
Argument "1": Conversion from "method group" to "object?" not possible.
<ul>
</li>
</ul>
Code:
@inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage
@using Umbraco.Cms.Core
@using Umbraco.Cms.Core.Models.PublishedContent
@using Umbraco.Cms.Core.Routing
@using Umbraco.Extensions
@inject IPublishedValueFallback PublishedValueFallback
@inject IPublishedUrlProvider PublishedUrlProvider
This snippet displays a list of links of the pages immediately under the top-most page in the content tree.
This is the home page for a standard website.
It also highlights the current active page/section in the navigation with the CSS class "current".
<ul>
</li>
</ul>
System:
Operating system name Microsoft Windows 11 Pro Insider Preview
Microsoft Visual Studio Community 2022
Version 17.3.1
VisualStudio.17.Release/17.3.1+32811.315
Microsoft .NET Framework
Version 4.8.09032
Version installed: Community
ASP.NET and Web Tools 17.3.375.53775
C#-Tools 4.3.0-3.22401.3+41ae77386c335929113f61d6f51f2663d2780443
C# components used in the IDE. Depending on your project type and related settings, a different version of the compiler may be used.
partial views not work
Hey!
I'm play today a little bit with umbraco to learn it with c#. After little start errors run the system now and i can work with that in Visual Studio. But now i have try to create a new "partial view" for the navigation with the template code, but if i reload the page they print errors. I understand the errors but i don't know what i can do for fix.
Errors:
Code:
System:
Hi Stefan,
If you are using Umbraco 8+ then it should be Model.Root(). As you have posted this question marking Umbraco 9, below is how your code should be
Pasang
It works well
Thanks for your solution
Great 👍
