  • Rizwan 30 posts 140 karma points
    Aug 22, 2022 @ 05:38
    Rizwan
    Navigation from site settings root node
    Dear Experts. I have a document type called site settings in root node. site settings has nested content with single multiurl picker and title and multiurl picker for child pages. in my partial view i am able to access the node site settings and nested content properties which shows data i added. when i try to access the properties i cant able to get the data.
     @inherits UmbracoViewPage
    @using Umbraco.Cms.Core.Models;
    @using Umbraco.Cms.Web.Common.PublishedModels;
    @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels;
        var siteSettings = Umbraco.ContentAtRoot().FirstOrDefault(x => x.ContentType.Alias == "siteSettings");
        var navigationItems = siteSettings.Value<IEnumerable<IPublishedElement>>("mainNavigation");
    @if(navigationItems!=null && navigationItems.Any())
        <ul class="nav nav-pills" id="mainNav">
            @foreach(var item in navigationItems)
                var hasChildLinks = item.ChildLinks;//unable to access childlinks property
        </ul>
    Aug 23, 2022 @ 13:34
    Huw Reddick
    you need to do something like below
    var hasChildLinks = item.Value<T>("childLinks");
