  • Daniel Rogers 143 posts 742 karma points
    Aug 25, 2022 @ 03:55
    Daniel Rogers
    Access current properties inside UmbracoAuthorizedJsonController
    I have a UmbracoAuthorizedJsonController that I are calling a function from a js code for a customized App_Plugin.
    This is an upgrade from a v8 umbraco App plugin to v 10.1.0
    I need to get the current page property .
    in version 8 my code was
    foreach (IDataType dataType1 in _dataTypeService.GetAll().Where<IDataType>((Func<IDataType, bool>)(x => x.EditorAlias == "IBD.PaperFlow.Plugin")))
                    if (dataType1.Key.ToString() == dataTypeKey)
                        dataType = _dataTypeService.GetDataType(dataType1.Id);
                        break;
    var propEditor = current.PropertyEditors.Where(x => x.Alias == dataType.EditorAlias).FirstOrDefault();
    I cannot find how I get the current property editors in version 10. The following line is the issue.
  • Mario Lopez 168 posts 958 karma points MVP 5x c-trib
    Aug 27, 2022 @ 07:03
    Mario Lopez
    Try this:
      int myId = 123;
      var paperFlowDataTypes = _dataTypeService.GetByEditorAlias("IBD.PaperFlow.Plugin");
      var myDataType = paperFlowDataTypes.FirstOrDefault(x => x.Id == myId);
      var propEditor = myDataType.Editor;
      // do your thing with the editor
    Sep 25, 2022 @ 14:07
    Daniel Rogers
    Turns out what I was trying to achieve was really easy.
    I just needed to pass the value from the App_plugin $scope.model.config."value" to the controller and done.
