I am currently in the situation where I have to bulk-delete a bunch of nodes. Now since I do not wish to loose database integrity, I'd rather set the trashed flag in the database to then let the CMS delete all of these nodes. Now I need to query for a specific bunch of nodes under a specific parent node with specific content.
Now this would be as easy as: (Values redacted ofc)
SELECT *
FROM [dbo].[umbracoPropertyData]
WHERE varcharValue like 'VALUE' AND id IN (SELECT id FROM [dbo].[umbracoNode] WHERE parentId = 1337);
If the relation was made from umbracoPropertyData to umbracoNode, which is of course impossible.
Does anyone have a fitting query for this sort of ordeal? Or any idea to where I can make the relation?
The Property Data is related to the Content Version, which is in turn related to the Umbraco Node.
Every time you save a content item in Umbraco a new Version is created, and consequently the Content Version and all the related Property Data gets updated. There is a flag in the Content Version for 'Current' which reflects what the Current saved version is.
so something like this
SELECT top 100 *
FROM [umbracoPropertyData] upd
INNER JOIN umbracoContentVersion ucv
ON upd.versionId = ucv.id
INNER JOIN umbracoNode un
ON un.id = ucv.nodeId
WHERE ucv.[current] = 1
AND un.ParentId = 1234
Would give you the kind of join you are looking for I think...
Query for content via SQL to bulk-trash nodes
Hello Umbraco Community!
Best regards
Joshua
Hi Joshua
regards
Marc
Nevermind my first answer! Yes this shows me the data in relation! I can now set the trashed flag accordingly!
Thank you very much!
