Running Umbraco v10 in .NET 6' minimal hosting model
Is it possible to run Umbraco v10 in .NET 6' minimal hosting model? By this I mean the new way of bootstrapping .NET 6 applications with just a Program.cs file instead of a Program.cs and Startup.cs, as it was for .NET 5.
I've come this far, but keep running into errors related to ambiguous controller registrations:
var builder = WebApplication.CreateBuilder(args);
builder.Services.AddUmbraco(builder.Environment, builder.Configuration)
.AddBackOffice()
.AddWebsite()
.AddComposers()
.Build();
builder.Services.AddRazorPages();
var app = builder.Build();
if (!app.Environment.IsDevelopment())
app.UseExceptionHandler("/Error");
// The default HSTS value is 30 days. You may want to change this for production scenarios, see https://aka.ms/aspnetcore-hsts.
app.UseHsts();
app.UseHttpsRedirection();
app.UseStaticFiles();
app.UseUmbraco()
.WithMiddleware(u =>
u.UseBackOffice();
u.UseWebsite();
.WithEndpoints(u =>
u.UseInstallerEndpoints();
u.UseBackOfficeEndpoints();
u.UseWebsiteEndpoints();
app.UseUmbracoRouting();
app.UseRouting();
app.UseAuthorization();
app.MapRazorPages();
//await app.InitializeApplicationAsync();
app.Run();
I keep getting this error on app.Run():
System.ArgumentNullException: 'Value cannot be null. (Parameter 'provider')'
app.Run():System.ArgumentNullException: 'Value cannot be null. (Parameter 'provider')'What am I missing here? Thanks in advance!
Raymond
I tried and failed. I created a startup file like in core 5.0
startup.cs
Minimal hosting model may or may not be supported yet, someone seems to have made it work in the comments here: https://github.com/umbraco/Umbraco-CMS/issues/12445#issuecomment-1227264825
Thanks Sebastiaan. Even though that work-around does run Umbraco 10, it doesn't play nice with the
AppModuleparadigm used by ABP.io.I'd be interested to see if both can be combined into one project.
