I'm trying to create a new index using Examine 3 in an Umbraco 10 project.
I'm following the documentation for Umbraco 10 to create a custom index - https://our.umbraco.com/Documentation/Reference/Searching/Examine/indexing/#creating-your-own-index.
The index is registered and I can see it in the backoffice, but it has no records in it and I cannot rebuild it through the backoffice because:
This index cannot be rebuilt because it has no assigned IIndexPopulator.
I have created a ProductIndexPopulator:
public class ProductIndexPopulator : IndexPopulator { private readonly IContentService _contentService; private readonly ProductIndexValueSetBuilder _productIndexValueSetBuilder; public ProductIndexPopulator(IContentService contentService, ProductIndexValueSetBuilder productIndexValueSetBuilder) { _contentService = contentService ?? throw new ArgumentNullException(nameof(contentService)); _productIndexValueSetBuilder = productIndexValueSetBuilder ?? throw new ArgumentNullException(nameof(productIndexValueSetBuilder)); RegisterIndex("ProductIndex"); } protected override void PopulateIndexes(IReadOnlyList<IIndex> indexes) { // blah blah blah } }
And registered it in a composer:
public class SearchComposer : IComposer { public void Compose(IUmbracoBuilder builder) { builder.Services.AddExamineLuceneIndex<ProductIndex, ConfigurationEnabledDirectoryFactory>("ProductIndex"); builder.Services.ConfigureOptions<ConfigureProductIndexOptions>(); builder.Services.AddSingleton<ProductIndexValueSetBuilder>(); builder.Services.AddSingleton<ProductIndexPopulator>(); } }
Anybody seen this issue before/know what I'm missing?
I don't think the docs are accurate and I can't find any U10 examples.
I was having the exact same issue, I have been able to register the IndexPopulator correctly, however when I add the Validator into the Index to restrict to a certain document type it stops working.
In the composer:
becomes
builder.Services.AddSingleton<IIndexPopulator, ProductIndexPopulator>();
But as I said, even though the index can now be built / rebuilt it will be empty if you try to restrict it
Does it register and populate WITHOUT the Validator?
Yep, if I remove the validator it works.
By the validator I mean this line:
options.Validator = new ContentValueSetValidator(true, false, _publicAccessService, _scopeProvider, includeItemTypes: new List<string>{"product"});
I've had some code given to me by @AndreyKarandas4 on Twitter which works
using Examine; using Examine.Lucene; using Microsoft.Extensions.Logging; using Microsoft.Extensions.Options; using Umbraco.Cms.Core.Hosting; using Umbraco.Cms.Core.Services; using Umbraco.Cms.Infrastructure.Examine; public class MapIndex : UmbracoExamineIndex, IUmbracoContentIndex, IDisposable { private string[] contentTypes = new string[] { "documentType" }; public MapIndex( ILoggerFactory loggerFactory, string name, IOptionsMonitor<LuceneDirectoryIndexOptions> indexOptions, IHostingEnvironment hostingEnvironment, IRuntimeState runtimeState) : base(loggerFactory, name, indexOptions, hostingEnvironment, runtimeState) { loggerFactory.CreateLogger<MapIndex>(); LuceneDirectoryIndexOptions namedOptions = indexOptions.Get(name); if (namedOptions == null) { throw new InvalidOperationException($"No named {typeof(LuceneDirectoryIndexOptions)} options with name {name}"); } namedOptions.FieldDefinitions = new( new("id", FieldDefinitionTypes.Integer) ); if (namedOptions.Validator is IContentValueSetValidator contentValueSetValidator) { PublishedValuesOnly = contentValueSetValidator.PublishedValuesOnly; } } void IIndex.IndexItems(IEnumerable<ValueSet> values) => PerformIndexItems(values.Where(v => contentTypes.Any(x => x == v.ItemType)), OnIndexOperationComplete); }
Then in your composer:
builder.Services.AddExamineLuceneIndex<MapIndex, ConfigurationEnabledDirectoryFactory>("indexName");
Indeed, when following this tutorial I was getting the same: https://docs.umbraco.com/umbraco-cms/v/10.latest-lts/reference/searching/examine/indexing
However this seemed to be due that I did not replace reference to "ProductIndex" in RegisterIndex call in IndexPopulator.
RegisterIndex
IndexPopulator
Once I replaced it with my index name - it started working.
Umbraco 10 custom index registering but not populating due to IIndexPopulator
I have created a
ProductIndexPopulator:And registered it in a composer:
In the composer:
becomes
RegisterIndexcall inIndexPopulator.Once I replaced it with my index name - it started working.
