Using umbraco 10 in a domain driven design architecture
Dears,
I am going to use umbraco 10 in a domain driven design solution.
So the solution will include the following projects
Application
Domain
Persistence
Infrastructure
Presentation
I am still thinking where should I locate generated models and services that will retrieve or add content.
Solution # 1
Create a domain model with the same properties as back-office but will generate models in persistence layer.
Create interfaces like repositories in application layer but implementations will be in persistence layer also
Pros:
Application and Domain layers will be fully independent "I mean will not depend on Umbraco"
Persistence layer will be the only layer that depend on Umbraco and i think this is meet the clean architecture
Cons:
Implementation will be more complex and needs lots of mapping operations to map between domain entities, DTOs and generated models
Solution # 2
Generate back-office models in domain layer
Pros:
Easy to implement
Cons:
Domain layer will depend on Umbraco and i think this is will violate clean architecture as domain layer shouldn't depend on any other layer, frameworks, libraries or a 3rd party.
So can u help me to decide which is the best solution or can you suggest a new solution?
Dears,
I am going to use umbraco 10 in a domain driven design solution. So the solution will include the following projects
Solution # 1
Create a domain model with the same properties as back-office but will generate models in persistence layer. Create interfaces like repositories in application layer but implementations will be in persistence layer also
Solution # 2
Generate back-office models in domain layer Create interfaces like repositories in application layer but implementations will be in persistence layer also
Easy to implement
Thanks in advance...
