I have a solution I'm attempting to upgrade from Umbraco 9 to Umbraco 10.
Umbraco.Cms 9.5.2
Umbraco.Forms 9.3.0
No unattended upgrade settings have been configured
Running the upgrade process as documented results in the issue described here: An infinite redirect to ~/account/accessdenied which eventually stalls because the redirect query parameter grows too long.
The user logged in to apply the upgrade has full administrator permissions.
The logs show that despite the error, an upgrade is still carried out behind the scenes.
Following the workaround outlined in the above thread, or stopping and restarting the solution results in the issue described here: An error that indicates an Umbraco.Forms version mismatch:
-> Umbraco.Cms.Core.Exceptions.BootFailedException: The migration plan does not support migrating from state "236973fb-2461-40d0-8e04-cb74e15481fa".
Removing Umbraco.Forms from the solution entirely and upgrading just Umbraco.Cms to version 10 is successful. Attempting to then restore and upgrade Umbraco.Forms to version 10 separately results in the same issues as above.
It seems like the Umbraco.Forms upgrade isn't completing correctly, and leaving the database in an unrecoverable state.
Umbraco Forms 9 to 10 Upgrade Issues
~/account/accessdeniedwhich eventually stalls because the redirect query parameter grows too long.The user logged in to apply the upgrade has full administrator permissions.
Any ideas on how I can resolve this?
It says here you need to be at the latest minor of Forms, before upgrading to 10.x.x https://our.umbraco.com/Documentation/Add-ons/UmbracoForms/Installation/Version-Specific#100
Thanks Søren, that has done the trick.
Do you know what it is about the early 9.x to 10 upgrade that makes this necessary?
I think it has to do with the change to SQLite in Umbraco 10 https://github.com/umbraco/Umbraco.Forms.Issues/issues/892#issuecomment-1268026958
Excellent, thank you again!
