  • Marshall Penn 86 posts 271 karma points
    Oct 19, 2022 @ 17:16
    Marshall Penn
    Okta SSO Login Problems - Umbraco 8.18.5
    We implemented the Okta Umbraco integration via this tutorial:
    https://effect.nz/our-thoughts/november-2021/umbraco-and-okta-integration/
    It does the login seemingly correctly, as can be seen by the event logging in the Okta application control panel - however when it redirects back to Umbraco we get this error
    "Sequence contains more than one element"
    [InvalidOperationException: Sequence contains more than one element]
       System.Linq.Enumerable.SingleOrDefault(IEnumerable`1 source) +504
       Microsoft.Owin.Security.<AuthenticateAsync>d__20.MoveNext() in /_/src/Microsoft.Owin/Security/AuthenticationManager.cs:156
    etc etc
    On this Stack Overflow post (https://stackoverflow.com/questions/27101402/sequence-contains-more-than-one-element-microsoft-owin-security-authenticationma) they seem to point at their being two authenticated "objects" which is causing the exception in the MS code at this point:
    public async Task<AuthenticateResult> AuthenticateAsync(string authenticationType)
      IEnumerable<AuthenticateResult> source = await this.AuthenticateAsync(new string[] { authenticationType });
      return source.SingleOrDefault<AuthenticateResult>(); //<== this line throws because there are two
    Can anyone shine a light on what might be happening?
    Thanks, Marshall
