  • Darren Hunter 140 posts 232 karma points
    Oct 24, 2022 @ 15:16
    Darren Hunter
    Umbraco Forms not Rendering correctly in Umbraco 10.
    I am trying to update a .Partial View Macro Page from:
    to @inherits Umbraco.Cms.Web.Common.Macros.PartialViewMacroPage @using Umbraco.Cms.Core.Models; @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels; @inject Microsoft.AspNetCore.Http.IHttpContextAccessor HttpContextAccessor
    But when I run the the following line of code
    Html.RenderPartial("RenderForm", "UmbracoForms", new ViewDataDictionary(ViewData));
    It says it can't find the view. The original code on version 8 of umbraco is
    Html.RenderAction("RenderForm", "UmbracoForms", new {formId = form, recordId = recordGuid, theme = theme, includeScripts = true });
    What the correct code I need to use,
  • Marc Goodson 2155 posts 14408 karma points MVP 9x c-trib
    Oct 27, 2022 @ 19:15
    Marc Goodson
    HI Darren
    If I understand correctly I think you need something like this on V10
    var formGuid = "TheGuidOfYourFormFromAPickerOrSomething";
    var yourThemeName = "NameOfYourFormsTheme";
    @await Umbraco.RenderMacroAsync("renderUmbracoForm", new {FormGuid=formGuid, FormTheme=yourThemeName , ExcludeScripts="0"})
    having ExcludeScripts ="0" or "1" depending on fi you want to have them included or if they are in your front end build.
    regards
    Marc
    Oct 28, 2022 @ 07:35
    Darren Hunter
    Thank you
