From: [TimeoutException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond] I'd say your site cannot connect to the MySQL server you have configured in web.config (check the connection string).
I've double checked all the credentials and have made sure to use localhost for the connection. Still getting the same error unfortunately so I dont believe its an issue with the DB connection string itself. The user permissions are also all correct for the db user.
Error on load.
I'm hoping someone here may be able to shed some light on this issue I'm having. Whenever I attempt to connect to my site the following error occurs:
I should note that the site has recently been moved to a new server. However, I have ensured the same versions of software are running.
Does anyone have any ideas? I cant really discern much from that output.
Any ideas would be appreciated.
[TimeoutException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond]I'd say your site cannot connect to the MySQL server you have configured in web.config (check the connection string).I've double checked all the credentials and have made sure to use localhost for the connection. Still getting the same error unfortunately so I dont believe its an issue with the DB connection string itself. The user permissions are also all correct for the db user.
