We have updated the Plumber workflow to 2.1.9. All the users are experiencing the infinite spinning of the Request Publish button. Could someone please assist?
Hey Anil, I'd guess that this is due to the unpublished ancestor nodes - not sure why that would impact submitting the workflow, but it will prevent completing as the node won't be publishable.
Things to confirm:
- the current node has workflow configured
- if not, an ancestor node has workflow configured
- current Umbraco version
- any logged errors (either browser console or Umbraco logs)
Detailed Analysis on Server:
I have verified the following from the server which has version 2.0.2 without the upgrade
I have verified the ancestor nodes are all published.
No workflow is configured
3.Current Umbraco Version is 8.18.5
4.Error on server is only when you Request publish for first time in server with version 2.0.2.
5.Able to complete the Request publish on the second time when you return to the same node by going out to ancestral node and returning back to the child node.
Plumber Upgrade issues on local:
Something is wrong after upgrading to the version 2.1.9. I am receiving the following errors along with Request Publish errors while navigating through the workflow section in local where as these are working in the server with version 2.0.2
Those errors all look like caching - I've just installed a clean 2.1.9 into latest Umbraco 8, requests are different eg the last screenshot requests /Plumber/Groups/GetPage/true/1/10000, correct URL is /Plumber/Groups/GetPage?slim=false&page=1&count=10&filter=
Try clearing all caches and incrementing the client dependency version number.
The first issue may be related, I'll need more time to investigate.
Thank you for your response.. I have just cleared the Cache and incremented the Client dependency. It seems like this resolved most of the 404 errors in console. However, I see the Request Publish is disabled and couldn't make it enabled in any way. Any thoughts?
I can't reproduce the disabled button, but have tracked down the previous issue - it's related to new content in a list view. Will look into exactly what's going on.
Appreciate for looking into the issue. Would you suggest any earlier versions to upgrade from 2.0.2 instead of 2.1.9 in meantime so that we can move things going ?
Plumber Workflow for Umbraco- Trouble shooting
Appreciate your response!!
Things to confirm: - the current node has workflow configured - if not, an ancestor node has workflow configured - current Umbraco version - any logged errors (either browser console or Umbraco logs)
@Nathan Woulfe
Appreciate your quick response.
Detailed Analysis on Server: I have verified the following from the server which has version 2.0.2 without the upgrade
Plumber Upgrade issues on local: Something is wrong after upgrading to the version 2.1.9. I am receiving the following errors along with Request Publish errors while navigating through the workflow section in local where as these are working in the server with version 2.0.2
/Plumber/Groups/GetPage/true/1/10000, correct URL is/Plumber/Groups/GetPage?slim=false&page=1&count=10&filter=Try clearing all caches and incrementing the client dependency version number.
Hi Anil
@Nathan Woulfe..
Thanks, Anil Kumar
