  • Pagggy 28 posts 71 karma points
    Nov 09, 2022 @ 13:37
    Pagggy
    media uploaded using code is not setting correct property data causing un selectable when picking from media picker
    Hi, I am uploading media file using following code and media created correctly but it is setting "umbracoFile" as media link instead of json object with cropper. Correct Property data
    Wrong property data
                var isImage = file.Name.ContainsAny(new[] { ".jpg", ".jpeg", ".bmp", ".gif", ".png" });
            var mediaTypeAlias = isImage ? ImageMediaTypeAlias : FileMediaTypeAlias;
            var fileName = Path.GetFileName(file.FullName);
            long children = 0;
            var mapMediaChildren = ms.GetPagedChildren(parentId, 0, 1000, out children);
            var mapMedia = mapMediaChildren.FirstOrDefault(c => c.Name == (name ?? fileName)); // look for same file name
            if (mapMedia == null)
                mapMedia = ms.CreateMediaWithIdentity(name ?? fileName, parentId, mediaTypeAlias,userId:393);
                var buffer = System.IO.File.ReadAllBytes(file.FullName);
                mapMedia.SetValue(Constants.Media.Bytes, file.Length);
                mapMedia.SetValue(Constants.Media.Extension, file.Extension.Replace(".",""));
                int newImgHeight = 0;
                int newImgWidth = 0;
                //Bitmap img = new Bitmap(file.FullName);
                using (Image img = Image.FromFile(file.FullName))
                    newImgHeight = img.Height;
                    newImgWidth = img.Width;
                mapMedia.SetValue(Constants.Media.Height, newImgHeight);
                mapMedia.SetValue(Constants.Media.Width, newImgWidth);
                using (var stream = new MemoryStream(buffer))
                   // mapMedia.SetValue("umbracoFile", null); // Set the file item to null as when upload to same media it was throwing error Illegal characters in path. Ref: http://issues.umbraco.org/issue/U4-9904
                    mapMedia.SetValue(contentTypeBaseServiceProvider, "umbracoFile", file.Name, stream);
                ms.Save(mapMedia);
            return mapMedia;
