  • Robert Johnston 16 posts 106 karma points
    Dec 08, 2022 @ 19:24
    Robert Johnston
    Block with Macro Select option without RTE
    Good morning everyone, I just want to see if there is a way to create a block that allows you to select a macro and its parameters - like the old grid editor had. I'm working in Umbraco 11 where the grid editor no longer is an option to use.
    Thanks.
  • Huw Reddick 1559 posts 5359 karma points MVP c-trib
    Dec 08, 2022 @ 19:40
    Huw Reddick
    I don't think so, I replaced my macros with a blockgrid component and viewcomponent to render it. I'm travelling at the moment, but can post an example over the weekend
  • Austin Gilbert 2 posts 73 karma points
    Dec 15, 2022 @ 23:07
    Austin Gilbert
    I was just trying to find a way to do this myself. Currently there isn't a property editor for that. However you could try making your own "Macro Picker" property editor yourself by reusing/copying the existing Backoffice angular controllers and razor files from the existing macro grid editor.
    That way you'd be able to make data types that can be added to your block grid document types. I might try requesting this property editor to be an OOTB feature in Umbraco's GitHub if there isn't any plans to phase out macro views.
    https://docs.umbraco.com/umbraco-cms/extending/property-editors
    Dec 27, 2022 @ 20:56
    Robert Johnston
    Just wanted to say thank you everyone for the response, I went with creating a block with the parameters I would have used in the macro.
    I really do hope that they add a macro select property editor in the future.
    Thanks again everyone.
  • Tom Newt 15 posts 136 karma points
    1 week ago
    Tom Newt
    Hi Robert, what do you have in your partial view for the block element to get the macro to display? Currently I'm adding macros through the rich text editor but I really don't like that workflow.
