  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Dec 09, 2022 @ 11:40
    Biagio Paruolo
    Using UmbracoMemberAuthorize in custom API controller: How to return only 401 code and not the error page?
    I've this code:
                [UmbracoMemberAuthorize("", "Socio", "")]
        [ActionName("Content")]
        [HttpGet]
        public async Task<IActionResult> Content(Guid id)
            var content = _contentService.GetById(id);
            var flag = await IsAuthorizedToSeeData(id);
            if (flag)
                return Ok(ContentFor(id));
            else
                return Unauthorized();
    I wish to return 401 and not go to the login/error page.
  • Sean Valentine 12 posts 101 karma points
    Dec 17, 2022 @ 17:27
    Sean Valentine
    Bumping this as i could really do with knowing how to solve this issue as well.
    Dec 18, 2022 @ 06:41
    Huw Reddick
    Not exactly sure what you are attempting to do, so perhaps you could explain a little more.
    The UmbracoMemberAuthorize attribute checks if your logged in member has access to the action being called and is idependant of the actual code in your action, maybe you should be using a custom authorise attribute for what you require.
