I have downloaded the sample block grid website from nuget and all works great.
Is there a way to make the grid response (stack above each other) by altering the sample stylesheet provided? (myblockgridlayout.css)
I haven't used css grid before and wondered if anyone can shed some light?
.umb-block-grid__layout-container { position: relative; display: grid; grid-template-columns: repeat(var(--umb-block-grid--grid-columns, 1), minmax(0, 1fr)); grid-auto-flow: row; grid-auto-rows: minmax(50px, min-content); column-gap: var(--umb-block-grid--column-gap, 0); row-gap: var(--umb-block-grid--row-gap, 0); } .umb-block-grid__layout-item { position: relative; /* For small devices we scale columnSpan by three, to make everything bigger than 1/3 take full width: */ grid-column-end: span min(calc(var(--umb-block-grid--item-column-span, 1) * 3), var(--umb-block-grid--grid-columns)); grid-row: span var(--umb-block-grid--item-row-span, 1); } .umb-block-grid__area-container, .umb-block-grid__block--view::part(area-container) { position: relative; display: grid; grid-template-columns: repeat(var(--umb-block-grid--area-grid-columns, var(--umb-block-grid--grid-columns, 1)), minmax(0, 1fr)); grid-auto-flow: row; grid-auto-rows: minmax(50px, min-content); column-gap: var(--umb-block-grid--areas-column-gap, 0); row-gap: var(--umb-block-grid--areas-row-gap, 0); } .umb-block-grid__area { position: relative; height: 100%; display: flex; flex-direction: column; /* For small devices we scale columnSpan by three, to make everything bigger than 1/3 take full width: */ grid-column-end: span min(calc(var(--umb-block-grid--area-column-span, 1) * 3), var(--umb-block-grid--grid-columns)); grid-row: span var(--umb-block-grid--area-row-span, 1); } @media (min-width:1024px) { .umb-block-grid__layout-item { grid-column-end: span min(var(--umb-block-grid--item-column-span, 1), var(--umb-block-grid--grid-columns)); } .umb-block-grid__area { grid-column-end: span var(--umb-block-grid--area-column-span, 1); } } /**** Custom additions to the default Grid Layout Stylehseet: ****/ /* additional CSS options for area-container and areas: */ .umb-block-grid__area-container, .umb-block-grid__block--view::part(area-container) { max-width: var(--my-container-max-width); padding: var(--my-container-padding); margin-left: auto; margin-right: auto; --umb-block-grid--areas-column-gap: 60px; --umb-block-grid--areas-row-gap: 60px; } .umb-block-grid__area { justify-content: center; } .umb-block-grid__layout-item[data-content-element-type-alias="oneColumnSectionBlock"] .umb-block-grid__layout-container { --umb-block-grid--column-gap: 60px; --umb-block-grid--row-gap: 60px; }
Did you find a solution?
Actually here are some good settings, for making the grid more responsive:
section { padding: var(--section-padding, 10px 0); /*control spacing between section, adjust 10px*/
} @media (max-width: 991px) { .umb-block-gridarea { --umb-block-grid--grid-columns: 12 !important; --umb-block-grid--area-column-span: 12 !important; --umb-block-grid--area-row-span: 1 !important; } .umb-block-gridarea-container, .umb-block-grid__block--view::part(area-container) { --umb-block-grid--areas-column-gap: 0; --umb-block-grid--areas-row-gap: 0; }
.umb-block-grid__layout-item[data-content-element-type-alias="oneColumnSectionBlock"] .umb-block-grid__layout-container { --umb-block-grid--column-gap: 0; --umb-block-grid--row-gap: 0; } .rich-text { columns: inherit; } .rich-text h3, .rich-text p { width: 100%; }
Here's one that works in 11.1. Most px's swapped for em's:-
section { padding: var(--section-padding, 0.6em 0); /*control spacing between section, adjust 10px*/ } .umb-block-gridlayout-container { position: relative; display: grid; grid-template-columns: repeat(var(--umb-block-grid--grid-columns, 1), minmax(0, 1fr)); grid-auto-flow: row; grid-auto-rows: minmax(3em, -webkit-min-content); grid-auto-rows: minmax(3em, min-content); -moz-column-gap: var(--umb-block-grid--column-gap, 0); column-gap: var(--umb-block-grid--column-gap, 0); row-gap: var(--umb-block-grid--row-gap, 0); } .umb-block-grid__layout-item { position: relative; /* For small devices we scale columnSpan by three, to make everything bigger than 1/3 take full width: */ grid-column-end: span min(calc(var(--umb-block-grid--item-column-span, 1) * 3), var(--umb-block-grid--grid-columns)); grid-row: span var(--umb-block-grid--item-row-span, 1); padding: 0 0 1em 0; } .umb-block-grid__area-container, .umb-block-grid__block--view::part(area-container) { position: relative; display: grid; grid-template-columns: repeat(var(--umb-block-grid--area-grid-columns, var(--umb-block-grid--grid-columns, 1)), minmax(0, 1fr)); grid-auto-flow: row; grid-auto-rows: minmax(3em, -webkit-min-content); grid-auto-rows: minmax(3em, min-content); -moz-column-gap: var(--umb-block-grid--areas-column-gap, 0); column-gap: var(--umb-block-grid--areas-column-gap, 0); row-gap: var(--umb-block-grid--areas-row-gap, 0); } .umb-block-grid__area { position: relative; height: 100%; display: flex; flex-direction: column; /* For small devices we scale columnSpan by three, to make everything bigger than 1/3 take full width: */ grid-column-end: span min(calc(var(--umb-block-grid--area-column-span, 1) * 3), var(--umb-block-grid--area-grid-columns)); grid-row: span var(--umb-block-grid--area-row-span, 1); } @media (min-width:1024px) { .umb-block-grid__layout-item { grid-column-end: span min(var(--umb-block-grid--item-column-span, 1), var(--umb-block-grid--grid-columns)); } .umb-block-grid__area { grid-column-end: span min(var(--umb-block-grid--area-column-span, 1), var(--umb-block-grid--area-grid-columns)); } } /**** Custom additions to the default Grid Layout Stylehseet: ****/ /* additional CSS options for area-container and areas: */ .umb-block-grid__area-container, .umb-block-grid__block--view::part(area-container) { max-width: var(--my-container-max-width); padding: var(--my-container-padding); margin-left: auto; margin-right: auto; --umb-block-grid--areas-column-gap: 2em; --umb-block-grid--areas-row-gap: 1em; }
Umbraco 11 Block Grid
