  • Peter Cort Larsen 421 posts 1038 karma points
    Dec 16, 2022 @ 08:22
    Peter Cort Larsen
    Umbraco 11 JS changes not picked up
    I have a Umbraco 11 site.
    On prod. debug is set false, as it should be.
    When ever i for example make changes to a js file, these changes are not picked up on production, unless i set debug to true and after revert it back to false. This is pretty irritating, cant this be done automatically somehow?
    Dec 16, 2022 @ 09:34
    Dave Woestenborghs
    Hi Peter
    Can you provide some more info.
    Is it a js file used in a backoffice plugin or a js file used in the front end of your website ?
    If it's the last how are you rendering it.
    Dec 16, 2022 @ 10:43
    Peter Cort Larsen
    Its for the assets used on the frontend. According to the docs for umbraco 11, i use this approach (https://docs.umbraco.com/umbraco-cms/fundamentals/design/stylesheets-javascript#bundling-and-minification-for-javascript-and-css) for adding styles and scripts. As illustrated, i even tried to change the cache of the js file, by adding this at the end ?v=1, but that didnt help.
    Dec 16, 2022 @ 10:55
    Dec 16, 2022 @ 11:06
    Peter Cort Larsen
    Wow, those settings i have overlooked, since this i my first vers 11.
    Thanks, thats proably what i needed.
    Ill check it out.
