  • Bobi 352 posts 966 karma points
    Dec 16, 2022 @ 22:37
    Bobi
    Umbraco memberships on SQL
    Is membership data stored in sql secure if azure sql is used and back office IP restrictions are turned on to the /umbraco folder? Is anything else needed to ensure the fullest security to membership data stored in sql?
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Dec 18, 2022 @ 06:45
    Huw Reddick
    Hi Bobi,
    I gues that depends on exactly what you are meaning by secure? If you mean are member properties stored encrypted or in plain text, then the answer would be the latter. If you are refering to their passwords, then they are encrypted.
