    Dec 20, 2022 @ 14:34
    Huw Reddick
    An update broke .Net 6 and Umbraco 10.3.0-rc
    In regards to my earlier post https://our.umbraco.com/forum/using-umbraco-and-getting-started/110734-suddenly-started-getting-a-weird-exception-found it would appear that an update has broken Umbraco 10.3.2 on .Net 6
    Upgrading the site and it's consumed projects to Umbraco 11 and .Net 7 has resolved the issue.
    If I create a new clean v10 website it works fine, but as soon as I update to a v10.3.X it breaks giving me the error in my earlier post.
    I believe the culprit was a .net update to 6.0.12 (uninstalling the update didn't help, so will stick with Umbraco 11
    Dec 20, 2022 @ 14:51
    Huw Reddick
    Ok, it seems the issue only exists with 10.3.0-rc updating to any other version fixes the problem.
    The dev instance was still using the 10.3.0-rc as I had been playing with the BlockGrid which was subsequently removed from 10.3.x relase and I did not want to update to v11 as I wanted the code base to continue using the Umbraco 10 LTS version, looks like I can't do that now :( as the 10.3.0-rc no longer works in .net 6 for some reason!
  • Sebastiaan Janssen 5061 posts 15523 karma points MVP admin hq
    Dec 21, 2022 @ 13:02
    Sebastiaan Janssen
    FYI: the 10.4.0 release https://our.umbraco.com/download/releases/1040 will contain the Block Grid Editor again, RC will be available tomorrow.
    Dec 21, 2022 @ 13:17
    Huw Reddick
    Excellent news 🙂
    Dec 22, 2022 @ 10:23
    Huw Reddick
    Hi Sebastiaan,
    The 10.4.0-rc has fixed the issue, so no idea what the cause was, Its an odd one for sure!
