  • Naman Rawat 3 posts 73 karma points
    Dec 30, 2022 @ 06:33
    Naman Rawat
    Not able to bind data from Umbraco BlockList data by my API method
    This is my code
    public async Task<EmployeeDetailsLayout.EmployeeDetails> GetCompanyEmployeesLayoutpage(GenericContentPage genericContentPage)
                try
                    EmployeeDetailsLayout.EmployeeDetails listEmployeeLayout = new EmployeeDetailsLayout.EmployeeDetails();
                    if (_umbracoHelperAccessor.TryGetUmbracoHelper(out var umbracoHelper) is false)
                        throw new Exception("Unable to get Umbraco Helper");
                    var _node1 = umbracoHelper.Content(1257);
                    // var contentPage = GetGenericContentPage("companyemployees");
                    if (_node1 is not null)
                        var result = _node1.Value<dynamic>("Employees");
                        //   genericContentPage.BlockList.Select(x => x.GetCorrespondingElementModel()).ToList();
                        foreach (var item in result)
                            listEmployeeLayout.blockItems.Add(new EmployeeDetailsLayout.BlockItems { EmployeeName = item.Content.EmployeeName, EmployeeEmail = item.Content.EmployeeEmail, EmployeePosition = item.Content.EmployeePosition, EmployeePhone = item.Content.EmployeePhone, EmployeeImage= item.Content }) ;
                    // listEmployeeLayout = _mapper.Map<EmployeeDetailsLayout.EmployeeDetails>(listEmployeeLayout);
                    return listEmployeeLayout;
                catch (Exception ex)
                    throw ex;
  • Huw Reddick 1929 posts 6697 karma points MVP 2x c-trib
    Dec 30, 2022 @ 12:11
    Huw Reddick
    What is the exact error you are receiving?
    Jan 09, 2023 @ 12:28
    Naman Rawat
    I got the solution. Thank You.
