I'm having issues getting getting my URL picker to work, when I add it to my partial view it breaks the page.
Unforently I'm strugling getting any error messages, even adding debug to true I just get "This page isnt working"
This is the code Im struggling with
@{ var links = dashpanel.Value<IEnumerable<Link>>("dashLink"); if (links.Any()) { foreach (var link in links) { <a href="@link.Url" class="dash-div w-inline-block"> } } }
Full code below
@inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage @using Umbraco.Cms.Core.Models; @{ var dashList = Model.Value<IEnumerable<IPublishedElement>>("dashBoard"); } <div class="grid-wrapper"> <h1 class="heading-10"> Your Dashboard</h1> <div class="dash-column w-row"> @foreach (var dashpanel in dashList.Where(x => x.IsVisible())) { <div class="dash-col w-col w-col-2"> @{ var links = dashpanel.Value<IEnumerable<Link>>("dashLink"); if (links.Any()) { foreach (var link in links) { <a href="@link.Url" class="dash-div w-inline-block"> } } } @{ var dashimage = dashpanel.Value<MediaWithCrops>("dashIcon"); if (dashimage != null) { <img src="@dashimage.MediaUrl()" loading="lazy" width="46" alt="" class="dash-icon"> } } <div class="dash-item-name">@dashpanel.Value("dashItem")</div> </a> </div> } </div> </div>
Are there any errors in the Umbraco logs?
Nope no errors, I think its because of the end of the href tag comes after the code, as if I put the tag inside it works but its not how it should be.
is there a way around this?
Cheers
that would indicate there is something wrong with your code nesting, at a quick glance it is related to your
loop as you are creating a new href for each link, but your closing </a> is outside this loop so is not valid html
</a>
Issue with URL picker
Full code below
Cheers
</a>is outside this loop so is not valid htmlis working on a reply...
