  • Jesper Skjønnemand 66 posts 441 karma points c-trib
    Jan 03, 2023 @ 08:42
    Jesper Skjønnemand
    issue with special characters in tags
    I experience issues with property type tags when editors use the & character in tags, e.g. "Research & Development".
    My setup is this:
    First, I check the URL for a topic value.
    var topic = string.Empty;
    topic = string.IsNullOrEmpty(Request["t"])
      ? string.Empty
      : Request["t"];
    I then transform the value to lowercase.
    var topicLow = topic.ToLower();
    Finally I look for the lowercase topic value in an array named "everything".
    var myResult = everything.Where( x => x.Value<string[]>("topicTags").Select(s => s.ToLowerInvariant()).ToArray().Contains(@topicLow) );
    This works just fine in most cases, just not when the topic tag contains a & character.
    Possible reasons for this issue and suggestions for solutions will be much appreciated.
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Jan 03, 2023 @ 13:03
    Huw Reddick
    It is most likely being encoded
    Jan 17, 2023 @ 07:55
    Jesper Skjønnemand
    yup, encoding/decoding it was
