Use ContentService.SaveAndPublish in LB, one front-site works, another one is Page Not Found
Hi all,
I have an issue when trying to the copy and publish programmatically the content with LB deployment (2 front-site nodes + 1 backoffice node). However I got the issue then my content can be found one front-site node, another one is returned Page Not Found. I know I should wait for a while but it doesn't work at all.
There are my sample code for copying and publishing
var copiedContent = _contentService.Copy(sourceContent, targetParent.Id, true, false);
var publishedResult = _contentService.SaveAndPublish(copiedContent);
Each FrontSite and BackOffice is use explicit registrar as Umbraco Docs. I also use the SqlServer as DistributedCache, I don't share the Temp folder which contains the Lucene, each server use own disk to store.
Hi all,
And in the appsettings.json, in front sites
appsettings.json of BackOffice
Hope to get your help.
Regards
