  • DChad 5 posts 75 karma points
    Jan 04, 2023 @ 12:50
    DChad
    Umbraco 11 nesting Blockgrid inside Blockgrid
    I have set up a Blockgrid view for navigation that has the ability to add multiple navigation items - each of these nav items can also have multiple children (which are currently setup as a Blocklist editor)
    I can't get the children to render - I keep getting errors with this:
        var rowChild = (NavLinkItem)item.Content;
        if(rowChild.ChildItems == null || !rowChild.ChildItems.Any()) return;
        foreach(var item in rowChild.ChildItems)
                     var rowChildItem = (EventDate)item.Content;
                    <!--Should display child items here but keep getting breaking error here-->
    I'm actually a designer / front-end guy, so not so very knowledgeable with C#.
    What am I doing wrong? Any help for a noob would be much appreciated :)
    Here is my full code:
    @using Umbraco.Extensions
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<Umbraco.Cms.Core.Models.Blocks.BlockGridItem>
        var row = (NavigationRow)Model.Content;
        var settings = (NavigationComponentSettings)Model.Settings;
        if(settings?.Hide ?? false) { return; }
        if(row.NavigationItems == null || !row.NavigationItems.Any()) return;
        var navId = "nav-" + row.Key;
    <div class="@(settings?.ContainerSize ?? "container") @settings.ItemClass">
    <nav class="navbar fixed-top navbar-expand-lg navbar-dark bg-secondary">
      <div class="container">
        <div class="collapse navbar-collapse" id="navbarSupportedContent">
          <ul class="navbar-nav me-auto mb-2 mb-lg-0">
                foreach(var item in row.NavigationItems)
                    var rowItem = (NavLinkItem)item.Content;
                    var rowSettings = (NavigationItemSettings)item.Settings;
                    var childlinks = @rowItem.ChildLinks;
                    var collapseId = navId + "-navitem";
                    if (childlinks.Any())
                        if(rowSettings?.MegaMenuToggle ?? false)
                            <li class="nav-item dropdown has-megamenu">
                                <a class="nav-link dropdown-toggle" href="#" data-bs-toggle="dropdown"> @rowItem.Link.Name</a>
                                <div class="dropdown-menu megamenu" role="menu">
                                        <div class="row g-3">
                                            <div class="col-lg-3 col-6">
                                                <h6 class="title">@rowItem.Link.Name</h6>
                                                <ul class="list-unstyled">
                                                     @foreach (var link in childlinks)
        <li><a class="dropdown-item" href="@link.Url" target="@link.Target">@link.Name</a></li>
                                                </ul>
                            </li>
                        else {
                            <li class="nav-item dropdown">
                                <a href="#" class="nav-link dropdown-toggle"role="button" data-bs-toggle="dropdown" aria-expanded="false" id="@collapseId">
                                     @rowItem.Link.Name
                                </a>
                                 <ul class="dropdown-menu" aria-labelledby="@collapseId">
                                </ul>
                            </li>
                    else {
                        <li class="nav-item">
                            <a href="@rowItem.Link.Url" class="nav-link" target="@rowItem.Link.Target" id="@collapseId" title="@rowItem.Link.Name">
                                  @rowItem.Link.Name
                              </a>
                        </li>
                   // index++;
          </ul>
          <button class="btn btn-primary me-2" type="button">Main button</button>
          <form class="d-flex">
            <input class="form-control me-2" type="search" placeholder="Search" aria-label="Search">
            <button class="btn btn-primary" type="submit">Search</button>
          </form>
    </nav>
        document.addEventListener("DOMContentLoaded", function(){
            /////// Prevent closing from click inside dropdown
            document.querySelectorAll('.dropdown-menu').forEach(function(element){
                element.addEventListener('click', function (e) {
                    e.stopPropagation();
    </script>
  • Huw Reddick 1929 posts 6697 karma points MVP 2x c-trib
    Jan 04, 2023 @ 12:54
    Huw Reddick
    Hi DChad,
    What is the error you are getting?
    Jan 04, 2023 @ 13:35
    DChad
    Here's the error I get:
    Jan 04, 2023 @ 13:45
    Huw Reddick
    This is because you have re-used the local parameter item, just rename one of them :)
        foreach(var **item** in row.NavigationItems)
           foreach(var **item** in rowChild.ChildItems)
    rename the nested on to something else, for example
       foreach(var childitem in rowChild.ChildItems)
         var rowChildItem = (EventDate)childitem.Content;
    Jan 04, 2023 @ 14:02
    DChad
    Ah okay - that did it. I can't believe I didn't spot that. I just thought I was missing something bigger. Many thanks!
    It's working now.
              if(rowChild.ChildItems == null || !rowChild.ChildItems.Any()) continue;
     @foreach(var childitem in rowChild.ChildItems)
           <li><a href='' class="dropdown-item">@rowChildItem.Date</a></li>
    Jan 04, 2023 @ 14:09
    Huw Reddick
    No problem, we all get code blindness now and again :D
