I am trying to use the new block grid functionality in Umbraco.
Its seems to me that it aint responsive on the frontend. The new css used to render the areas, seems unnecessary complicated.
I dont understand why the complicated css is needed. Normally people use something bootstrap. Cant seem to find a way to use both bootstrap and all the css used for the block grid editor.
At the bottom of the Block Grid datataype, there is an option to download some default css to base your style sheet on, these default settings should make the grid more responsive
Block grid umbraco 11
Can someone help?
Found a way to change the generated html:
Here is a section:
That's quite a neat solution, I like it :)
To expand on your example, if you add the following then it will work if your column sizes are changeable.
Good idea
