  • Kristoffer Eriksen 185 posts 465 karma points
    Jan 19, 2023 @ 09:23
    Kristoffer Eriksen
    ContentSavingNotification is handled before required field-validation in Umbraco Backend
    Hey Umbraco-peeps
    I'm doing some content-handling on a node while saving, but the handle-method on the ContentSavingNotification is run even though I'm having some required fields on the contentnode. I'm using Umbraco V10.3.2.
    When doing the same in the clients current solution (8.6.4) and using the
    ContentService.Saving += ContentService_Saving;
    it's not run until every required field in the Umbraco Backend is correctly filled
    Is there another way in doing it, so I'm sure that every validation on fields, is done, before running the custom saving-code?
