  • Brygger92 9 posts 79 karma points
    Jan 19, 2023 @ 09:57
    Brygger92
    Nested Content in newer versions of umbraco
    what do you use instead of nestedContent in the newer versions of umbraco
    since it does not exist in 11.1.0 but it does in 8.14
    im sitting and updating the program
  • Garðar Þorsteinsson 104 posts 484 karma points
    Jan 19, 2023 @ 10:08
    Garðar Þorsteinsson
    I would recommend to use Block List.
    If you want it to work more like Nested Content you can choose inline editing mode on the datatype.
  • Lungelo Keswa 12 posts 93 karma points
    Jan 20, 2023 @ 09:49
    Lungelo Keswa
    hi i'm using block list i was doing nested content with it in umbraco 10 it was fine. now using umbraco 11 having issues with when i' using ITEM.CONTENT
    do you know how i can fix this please
    var rowItem = (AccordionItem)item.Content;
    @inherits UmbracoViewPage<BlockGridItem<AccordionRow>>
        var rowAccordion = (AccordionRow)Model.Content;
        if (rowAccordion.AccordionDetails == null || !rowAccordion.AccordionDetails.Any()) return;
        var accordionId = "accordion-" + rowAccordion.Key;
    <div cite="row">
        <div class="container">
            <div id="@accordionId">
                    var index = 0;
                    foreach (var item in rowAccordion.AccordionDetails)
                        var show = index == 0;
                        var headingId = accordionId + "heading-" + index;
                        var collapseId = accordionId + "collapse-" + index;
                                <div class="card">
                                    <div class="card-header" id="@headingId" style="margin-left: 0!important; margin-right: 0!important">
                                        <h5 class="mb-0">
                                            <button class="btn btn-link" data-toggle="collapse" data-target="@collapseId" aria-expanded="@show" aria-controls="@collapseId">
                                        @rowItem.Title
                                            </button>
                                        </h5>
                                    <div id="[email protected]" class="collapse @(show ? "show" : null)" aria-labelledby="@headingId" data-parent="@accordionId">
                                        <div class=" card-body">
                                    @rowItem.Content
                        index++;
  • Huw Reddick 1318 posts 4621 karma points c-trib
    Jan 20, 2023 @ 10:59
    Huw Reddick
    Is that your exact code? Yo have this at the top, but item is not defined there
    It would also help if you could provide the error you are getting.
    Jan 20, 2023 @ 11:03
    Lungelo Keswa
    Oh sorry man here is the error message
    'char' does not contain a definition for 'Content' and no accessible extension method 'Content' accepting a first argument of type 'char' could be found (are you missing a using directive or an assembly reference?)
    Jan 23, 2023 @ 21:04
    Lungelo Keswa
    hi Garðar Þorsteinsson can you please help me out with this error kinder stuck.
  • Nik 1554 posts 6876 karma points MVP 5x c-trib
    Jan 31, 2023 @ 22:51
    Nik
    Hi Brygger92,
    Did you manage to solve your issue in the end?
    Nik
