I'm working on an Umbraco 10.4 installation, and I'm trying to get the hang of the new BlockGrid.
So far, I'm loving it!
However, I just can't seem to read fields from the settings-node, within my custom view in the backend.
This page mentions a way to get a settings-value in the label field. https://docs.umbraco.com/umbraco-cms/fundamentals/backoffice/property-editors/built-in-umbraco-property-editors/block-editor/block-grid-editor#block-configuration-settings
label
And I can get to my settings in the front-end-view by using Model.Settings.Value(). But how do you get a settings-value within the custom view?
I've tried
{{settings.fieldname}}
{{block.fieldname}}
{{block.settings.fieldname}}
{{block.data.fieldname}}
{{block.data.settings.fieldname}}
It's probably a very simple answer, but I just can't find any info about it. And AngularJS isn't my strongest point ;)
Hi Jeroen,
I think it is block.settingsData.fieldname
Thanks, that was the solution.
It doesn't help that block-label, frontend and backend all have other names :) But it works now.
Getting Block-settings within a custom view
labelfield. https://docs.umbraco.com/umbraco-cms/fundamentals/backoffice/property-editors/built-in-umbraco-property-editors/block-editor/block-grid-editor#block-configuration-settingsAnd I can get to my settings in the front-end-view by using
Model.Settings.Value(). But how do you get a settings-value within the custom view?I've tried
{{settings.fieldname}}{{block.fieldname}}{{block.settings.fieldname}}{{block.data.fieldname}}{{block.data.settings.fieldname}}It's probably a very simple answer, but I just can't find any info about it. And AngularJS isn't my strongest point ;)
Hi Jeroen,
I think it is
block.settingsData.fieldnameThanks, that was the solution.
