  • Jorge 37 posts 119 karma points
    Jan 25, 2023 @ 18:02
    Jorge
    Parse text with macro into final output
    I have this simple text with macro from an external source.
    <p>asdfsadf</p>
    <?UMBRACO_MACRO macroAlias=""Map"" />
    <p>asdfasdf</p>"
    And I want this to display to my custom view but with the macro snippet converted correctly.
    If I try to paste it into one of Umbraco page rich text editor field it will render correctly as Umbraco will handle the conversion.
    However, that is not my case so I'm expecting to pull some custom code that will parse this text to render it correctly, and I'm not sure how to do that.
    I'm using Umbraco version 10
    Jan 26, 2023 @ 08:55
    Huw Reddick
    Hi Jorge,
    Not entirely sure what you are asking, but Macros are rendered using
    @await Umbraco.RenderMacroAsync("myMacroAlias")
