  • Meni 216 posts 390 karma points
    Jan 26, 2023 @ 07:07
    Meni
    Migrate to Umbraco 11.1: How to get nodes, then render images (@Umbraco.Media)
    Hi, I'm working on migrating my Umbraco 7.15.7 to 11.1
    I tried to render the images without success. I looked in the documentation, forum, etc. but couldn't figure out.
    Here's my code in 7.15.7:
    It's a partial view macro file where first I'm getting the nodes for the section
    var Imaging_node = Umbraco.Content(1234);
    var Imaging_pagesToList = @Imaging_node.Children.Where("Visible");
    Imaging_pagesToList = Imaging_node.DescendantsOrSelf().Where("NodeTypeAlias == @0", "NewsPage");
    Then I start display the images in few places, for example:
    @if (Imaging_pagesToList.Last().HasValue("articleImg"))
                        <img src="@Umbraco.Media(Imaging_pagesToList.Last().articleImg.ToString()).Url" class="img-fluid" alt="@Imaging_pagesToList.Last().photoAlt" />
    My questions are:
    Question 1:
    How can I get the nodes?
    and
    are not working and give me errors.
    What I was able to do is the following , but I'm not sure if it's the right way:
    var Imaging_pagesToList = @Imaging_node.Children.Where(x => x.IsVisible());
    Imaging_pagesToList = Imaging_node.DescendantsOrSelf().OfTypes("NewsPage");
    Question 2:
    How do I render the images??
    I tried many things, looked in the documentation, etc. and couldn't figure out.
    This is (again) how I do it in my 7.15 website:
    where articleImg is a property in the document types that display the page. and photoAlt is a property to show the image description
    Thanks for the help :)
  • Alex Skrypnyk 6083 posts 23482 karma points MVP 6x admin c-trib
    Jan 26, 2023 @ 14:47
    Alex Skrypnyk
    Hi Meni,
    Use this code:
    var Imaging_pagesToList = @Imaging_node.Children.Where(n => n.IsVisible());
    Imaging_pagesToList = Imaging_node.DescendantsOrSelf().Where(n => n.ContentType.Alias == "NewsPage");
    Thanks, Alex
    Jan 26, 2023 @ 15:58
    Meni
    Thanks.
    What about images? How do I render images in Umbraco 11?
    Jan 26, 2023 @ 17:09
    Alex Skrypnyk
    Something like this:
    <img src="@Umbraco.Media(Imaging_pagesToList.Last().Value<IPublishedContent>("articleImg").ToString()).Url()" class="img-fluid" alt="@Imaging_pagesToList.Last().Value("photoAlt")" />
    Jan 27, 2023 @ 05:50
    Meni
    Thanks, this works.
    Quick question: I tried also this (before you answered me) and this is also works:
    Is it also a correct way?
    Jan 27, 2023 @ 12:09
    Alex Skrypnyk
    yes, but it's better to use strongly typed variables
