  • Paul Seal 524 posts 2890 karma points MVP 8x c-trib
    Jan 29, 2023 @ 13:01
    Paul Seal
    Creating a Block List Data Type Programmatically
    I am getting an error when trying to create a block list data type programmatically.
    {"ExceptionMessage":"Value of type BlockListConfiguration cannot be a configuration for editor Umbraco.BlockList, expecting. (Parameter 'value')"
    The issue is when I am trying to set the configuration.
    Please can you help me work out where I am going wrong?
    Here is my code:
    public void CreateDataType(string name)
        var newDataType = new DataType(
            new DataEditor(_dataValueEditorFactory)
                Alias = "Umbraco.BlockList"
            }, _configurationEditorJsonSerializer)
            Name = name,
            Configuration = new BlockListConfiguration
                Blocks = new[]
                    new BlockListConfiguration.BlockConfiguration
                        ContentElementTypeKey = new Guid("08e05150-1fe7-4810-96d2-cc0b9fd77a40"),
                        SettingsElementTypeKey = new Guid("55876948-ac8b-440f-bbca-19ac2bb18189"),
                        Label = "{{ !$title || $title == '' ? 'Test ' + $index : $title }}",
                        EditorSize = "medium",
                        ForceHideContentEditorInOverlay = false,
                        Stylesheet = "",
                        View = "",
                        IconColor = "#ffffff",
                        BackgroundColor = "#1b264f"
                MaxPropertyWidth = "100%",
                UseSingleBlockMode = false,
                UseLiveEditing = false,
                UseInlineEditingAsDefault = false,
                ValidationLimit = new BlockListConfiguration.NumberRange()
                    Min = 0,
                    Max = 10
        _dataTypeService.Save(newDataType);
    Kind regards
    Paul
  • Sander Los 27 posts 160 karma points
    Jan 30, 2023 @ 06:04
    Sander Los
    Hi Paul,
    that is really weird. I get the same error when setting the configuration in the way you describe.
    I tried a couple of things and when I saved the DataType first (without the configuration) and set the configuration afterward (with the same values), the configuration is being set correctly. (below ugly/verbose code used for testing purposes)
    var config = new BlockListConfiguration{...}
    var testType = _dataTypeService.GetDataType(name);
    testType.Configuration = config;
    _dataTypeService.Save(testType);
    I hope someone else has some good insights on why it does not work when constructing it from scratch.
    Jan 30, 2023 @ 07:22
    Paul Seal
    I got it working. My friends Anders and Callum helped me in the MVP slack group.
    I’ll update this post later with the solution.
    Paul
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Oct 02, 2023 @ 17:00
    Steve Morgan
    Hi Paul,
    I'm trying to update a datatype configuration and wondered if you have this code to hand as it might give me the clues I need to solve a start node ID update problem I have?
    Kind regards
    Steve
    Oct 02, 2023 @ 17:52
    Oct 03, 2023 @ 10:00
    Steve Morgan
    Thanks, very useful.
    Looks like my approach is fine. I'm struggling to update an existing data type rather than create a new one.
