  • Pablo A. 2 posts 22 karma points
    Jan 30, 2023 @ 19:32
    Pablo A.
    Dear all,
    I could set the Two Factor authentication in the CMS. Following the documentation: https://docs.umbraco.com/umbraco-cms/reference/security/two-factor-authentication#notification-when-2fa-is-requested-for-a-user Now, I would like to know if it is possible to mark this security step as required. The users could choose if can enable or disable it, but I would like to know if exists the possibility to mark this as required, and dont allow to login to the user if this option is not available. Thanks in advance,
  • Alex Skrypnyk 6112 posts 23606 karma points MVP 7x admin c-trib
    Apr 04, 2023 @ 14:27
    Alex Skrypnyk
    Hi Pablo
    Did you find a way of doing this? Can you share?
    Thanks, Alex
    Apr 12, 2023 @ 06:53
    Pablo A.
    Hi Alex, Yes, I could complete this task, using the interface
    private readonly ITwoFactorLoginService twoFactorLoginService;
    and checking if the user has enabled that option:
    var twoFactorEnabled = await twoFactorLoginService.IsTwoFactorEnabledAsync(user.Key);
    Thanks in advance,
  • andrew shearer 499 posts 645 karma points
    Sep 21, 2023 @ 23:02
    andrew shearer
    hi Pablo - correct me if wrong, your suggestion above is just to check if its enabled for a given user.
    Is there a way to enforce 2FA is required for all users (especially when not already enabled). i.e. 2FA blanket required for all users, meaning that after the username/password login step that the workflow would then show the 2FA setup screen. (unless an Admin has opted a user out of 2FA for some reason, which i acknowledge is a valid use case, in which case the IsTwoFactorEnabled setting would be honoured)
    thanks
    26 days ago
    Alex Skrypnyk
    Hi Andrew,
    Did you succeed with this task?
    Alex
    26 days ago
    andrew shearer
    hi Alex, no i didn't find a way available in Umbraco to enforce that users go through a 2fa process to log in. To me this should've been an MVP feature of introducing 2fa.
    25 days ago
    Alex Skrypnyk
    Hi Andrew,
    Agree )
    Did you try this package - https://plugins.miniorange.com/umbraco-two-factor-authentication-2fa?
    Just curious, because I've just found it, looks like it has this feature
    Thanks, Alex
  • Jay 400 posts 616 karma points
    Oct 24, 2023 @ 11:26
    Jay
    Any update on this?
    26 days ago
    Alex Skrypnyk
    Update on this?
