  • Meni 216 posts 390 karma points
    Jan 31, 2023 @ 01:27
    Meni
    Render images in Umbraco 11
    Hi, In my Umbraco 7.15.7 I'm displaying images in the Partial Views Macro Files as follow:
    figure>
                        @if (newsItem.HasValue("articleImg"))
                            <img src="@Umbraco.Media(newsItem.articleImg.ToString()).Url" class="img-fluid news-img" alt="@newsItem.Last().photoAlt" />
    (the reason for the .ToString() is after I switched from Obsolete to Media.Picker2 - so since it's string)
    In my Umbraco 11.1 I was struggle to display the images. I tried the following and it didn't display the images, but also didn't throw an error, just didn't display the images:
    <img src="@Umbraco.Media(newsItem.Value<IPublishedContent>("articleImg").ToString()).Url()" class="img-fluid" alt="@Imaging_pagesToList.Last().Value("photoAlt")" />
    So I tried this one:
    <img src="newsItem.Value<IPublishedContent>("articleImg").Url()" class="img-fluid" alt="@newsItem.Value("photoAlt")" />
    And this one also doesn't show any image
    I also tried this one (the same as above, just with @ - @newsItem) , and this throw an error: "Argument 3: cannot convert from 'method group' to 'object?'":
    <img src="@newsItem.Value<IPublishedContent>("articleImg").Url()" class="img-fluid" alt="@newsItem.Value("photoAlt")" />
    var image = newsItem.Value<IPublishedContent>("articleImg");
    <img src="@image.Url()" class="img-fluid" alt="@newsItem.Value("photoAlt")" />
    And this is finally works! And I don't understand why? (why this works, and why the previous didn't work)
    My question are:
    1. Why only the last one works?
    2. Why the first two doesn't work?
    3. Is this is the right way to render images in Umbraco 11.1 ?
    Please advise.
    Thanks.
  • Huw Reddick 1333 posts 4657 karma points c-trib
    Jan 31, 2023 @ 08:14
    Jan 31, 2023 @ 15:19
    Meni
    Yes, I have read it before, but what it shows in the examples is parsing the Guid:
    var mediaItem = Umbraco.Media(Guid.Parse("55240594-b265-4fc2-b1c1-feffc5cf9571"));
    So I wasn’t sure how to get the Guid of each image? It wasn’t clear from the docs. It seems in the examples that they pretty much hard coding the Guid. But if I iterate over a node, how do I get the Guid of each item in a node? (each item in the node represents a page with a feature image)
    Let’s say I have a node which I’m iterating, how do I get the Guid for each node to retrieve the image?
    Feb 01, 2023 @ 08:07
    Huw Reddick
    If you follow the links for mediapicker etc it shows examples using the alias as well
    https://docs.umbraco.com/umbraco-cms/fundamentals/backoffice/property-editors/built-in-umbraco-property-editors/media-picker-3
    Feb 01, 2023 @ 19:20
    Meni
    Since I migrated from 7 in my database I'm still using Umbraco.MediaPicker (and not Umbraco.MediaPicker3)
    So I can't use IEnumerable
    Feb 01, 2023 @ 19:39
