  • Francesco 9 posts 89 karma points
    Feb 08, 2023 @ 08:55
    Francesco
    Sitemap with custom controller
    I'm trying to create a custom controller with a custom route but I can't get the Umbraco Context.
    This controller must render the sitemap of my website.
    This is how I register the route
    and this is the controller:
    In the ActionResult GetSitemapIndex I can't access the UmbracoContext: enter image description here
    What am I doing wrong? I hope the question is specific enough.
    Feb 08, 2023 @ 12:12
    Huw Reddick
    Hi Francesco,
    You already have the UmbracoContext passed in using DI, you just need to assign it to a local variable
    private readonly IUmbracoContextAccessor _context;
    Then in the constructor just assign it
    _context = umbracoContextAccessor;
    Feb 08, 2023 @ 13:03
    Francesco
    Thank you for your help!
    Unfortunately it does not work, any other ideas? enter image description here
    Feb 08, 2023 @ 14:33
    Huw Reddick
    What is ISitemapService ? It is that that is erroring, I have not come across this service in Umbraco.
    Feb 08, 2023 @ 14:37
    Francesco
    It's a custom service written by me, and it use another class that return false in this if statement
    if (!_umbracoContextAccessor.TryGetUmbracoContext(out var umbracoContext) || umbracoContext.Content == null)
    Feb 08, 2023 @ 15:02
    Huw Reddick
    Ok thanks for clarifying, so it is this service that is not getting an umbraco context rather than your controller.
    What does your service code look like?
    Feb 13, 2023 @ 15:38
    Francesco
    My service is this: enter image description here And in baseRepository: enter image description here
    I have the function that try to read umbracocontext: enter image description here
    The problem is that even if I use the UmbracoContextAccessor in the SitemapController during a debug session (I'm using Immediate Window) it says that "it wasn't able to get an UmbracoContext" like the screen before.
