  • Jay 425 posts 652 karma points
    Feb 14, 2023 @ 16:15
    Jay
    Using AutoMapper on V10
    Hi all,
    Anyone used Automapper on V10 before?
    I've used it in V8 and was trying to figure out how do I register and use AutoMapper in V10, can't find anything in the forum
    Thank you
  • Conor Howe 36 posts 137 karma points
    Feb 15, 2023 @ 11:58
    Conor Howe
    Is there a requirement to use AutoMapper or could you use the Umbraco mapper instead?
    https://docs.umbraco.com/umbraco-cms/reference/mapping/
  • Corné Hoskam 81 posts 588 karma points MVP 3x c-trib
    Feb 16, 2023 @ 13:51
    Corné Hoskam
    Hi Jay,
    I can confirm Automapper also works on V10, in our case using Automapper V12 on Umbraco V10. Are there any specific questions you need answering?
    Kind regards,
    Corné
    Feb 16, 2023 @ 14:26
    Jay
    Hi Corne,
    Do you use any Automapper Profile?
    I'm having issues using that to call the ForMember() to map properties from source to destination which are different.
    Feb 16, 2023 @ 14:29
    Corné Hoskam
    Hi Jay,
    We're using a bunch of different profiles, and even more Type & Value Converters in this specific project. Depending on the scale and custom models you wish to use, you will need to use more custom profiles & converters. You might want to look into the specific ForMember configuration issue that you're running into, as I don't see any Umbraco specific issues causing this (atleast in my experience so far!)
    Feb 22, 2023 @ 16:45
    Jay
    Hey Corne,
    Jumping back onto this.
    Quick one. Do you have the codes on how you add your profiles to the MapperConfiguration on startup?
    Got all thiose automapper profiles with me but it's not picking up
    thanks
