  • James Cordrey 11 posts 113 karma points
    Mar 01, 2023 @ 01:14
    James Cordrey
    Custom Index Issue
    So, this is a bit of a weird one. Currently running Umbraco V11.1.0
    When I set my composer up like this:
    builder.Services.ConfigureOptions<ConfigureEntwinedStudiosIndexOptions>();
    builder.Services.AddExamineLuceneIndex<EntwinedStudiosIndex, ConfigurationEnabledDirectoryFactory>("EntwinedStudiosIndex");
    builder.Services.AddSingleton<EntwinedStudiosIndexValueSetBuilder>();
    builder.Services.AddSingleton<IIndexPopulator, EntwinedStudiosIndexPopulator>();
    My index populates, but the options I've configured in the ConfigureEntwinedStudiosIndexOptions class are ignored. (Specifically published content is set to false, and itemTypes are not present.)
    The index shows all the options I expect it to, but nothing gets indexed.
    When content is indexed, this is what I see:
    This is what I see under the second composer configuration:
    I was following along at this link to try and figure out what I did wrong - but even when I set things up exactly the way this link has, I get the above results.
    I can probably live with using default indexing options if I need to, but I'd like to know if I'm doing something wrong here. I'm new to Examine and Index Manipulation.
    Thanks!
    Mar 01, 2023 @ 09:02
    Huw Reddick
    I just checked my custom index (which is working) it would appear I have removed the builder.Services.ConfigureOptions line, unsure why, but the index does work.
        builder.Services.AddExamineLuceneIndex<ForumIndex, ConfigurationEnabledDirectoryFactory>("ForumIndex");
        builder.Services.AddSingleton<ForumIndexValueSetBuilder>();
        builder.Services.AddSingleton<IIndexPopulator, ForumIndexPopulator>();
    Mar 01, 2023 @ 12:20
    James Cordrey
    Yeah, I tried that too - it indexes, but it appears to have the base configuration for an index, which is all document types and unpublished content.
    Which I could work around, but I'd rather know how to make the configuration options work.
    Mar 01, 2023 @ 13:44
    Huw Reddick
    I'll have a play later see if I can get anywhere :)
    Mar 01, 2023 @ 13:50
    James Cordrey
    I appreciate that!
