I am not able to delete Content node from Umbraco editor. I have all the access rights. I am able to create the content.
Same code and database is running fine on another environment or say other machine server.
I tried to use same code with fresh Umbraco database but still same issue.
Only difference between both server is Sql server instance. Server where i face issue, sql installed on linux server but i have admin rights on server and able to delete sql table using SSMS.
Please find the error, I received while delete node.
System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'alias'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.getMetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteDbDataReader(CommandBehavior behavior) in C:\projects\dotnet\src\MiniProfiler.Shared\Data\ProfiledDbCommand.cs:line 236
at Umbraco.Cms.Infrastructure.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func1 func)
at NPoco.Database.ExecuteReaderHelper(DbCommand cmd)
at NPoco.Database.ExecuteDataReader(DbCommand cmd)
at NPoco.Database.QueryImp[T](T instance, Expression1 listExpression, Func2 idFunc, Sql Sql)+MoveNext()
at System.Collections.Generic.List1..ctor(IEnumerable1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source)
at NPoco.Database.0[T](Page1 paged, Sql thesql)
at NPoco.Database.PageImp[T,TRet](Int64 page, Int64 itemsPerPage, String sql, Object[] args, Func3 executeQueryFunc)
at NPoco.Database.Page[T](Int64 page, Int64 itemsPerPage, String sql, Object[] args)
at NPoco.Database.Page[T](Int64 page, Int64 itemsPerPage, Sql sql)
at Umbraco.Cms.Infrastructure.Persistence.Repositories.Implement.TrackedReferencesRepository.GetPagedDescendantsInReferences(Int32 parentId, Int64 pageIndex, Int32 pageSize, Boolean filterMustBeIsDependency, Int64& totalRecords)
at Umbraco.Cms.Core.Services.Implement.TrackedReferencesService.GetPagedDescendantsInReferences(Int32 parentId, Int64 pageIndex, Int32 pageSize, Boolean filterMustBeIsDependency)
at Umbraco.Cms.Web.BackOffice.Controllers.TrackedReferencesController.GetPagedDescendantsInReferences(Int32 parentId, Int32 pageNumber, Int32 pageSize, Boolean filterMustBeIsDependency)
at lambdamethod1453(Closure , Object , Object[] )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
ClientConnectionId:ec0e807e-b7b2-4694-b20f-3a4980969c8e
Error Number:207,State:1,Class:16
Not able to Delete Content Node using editor
Hi Team,
I am not able to delete Content node from Umbraco editor. I have all the access rights. I am able to create the content. Same code and database is running fine on another environment or say other machine server. I tried to use same code with fresh Umbraco database but still same issue.
System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'alias'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action
1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.getMetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior) at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteDbDataReader(CommandBehavior behavior) in C:\projects\dotnet\src\MiniProfiler.Shared\Data\ProfiledDbCommand.cs:line 236 at Umbraco.Cms.Infrastructure.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func1 func) at NPoco.Database.ExecuteReaderHelper(DbCommand cmd) at NPoco.Database.ExecuteDataReader(DbCommand cmd) at NPoco.Database.QueryImp[T](T instance, Expression1 listExpression, Func2 idFunc, Sql Sql)+MoveNext() at System.Collections.Generic.List1..ctor(IEnumerable1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source) at NPoco.Database.0[T](Page1 paged, Sql thesql) at NPoco.Database.PageImp[T,TRet](Int64 page, Int64 itemsPerPage, String sql, Object[] args, Func3 executeQueryFunc) at NPoco.Database.Page[T](Int64 page, Int64 itemsPerPage, String sql, Object[] args) at NPoco.Database.Page[T](Int64 page, Int64 itemsPerPage, Sql sql) at Umbraco.Cms.Infrastructure.Persistence.Repositories.Implement.TrackedReferencesRepository.GetPagedDescendantsInReferences(Int32 parentId, Int64 pageIndex, Int32 pageSize, Boolean filterMustBeIsDependency, Int64& totalRecords) at Umbraco.Cms.Core.Services.Implement.TrackedReferencesService.GetPagedDescendantsInReferences(Int32 parentId, Int64 pageIndex, Int32 pageSize, Boolean filterMustBeIsDependency) at Umbraco.Cms.Web.BackOffice.Controllers.TrackedReferencesController.GetPagedDescendantsInReferences(Int32 parentId, Int32 pageNumber, Int32 pageSize, Boolean filterMustBeIsDependency) at lambdamethod1453(Closure , Object , Object[] ) at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync() at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync() --- End of stack trace from previous location --- at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync() --- End of stack trace from previous location --- at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted) ClientConnectionId:ec0e807e-b7b2-4694-b20f-3a4980969c8e Error Number:207,State:1,Class:16is working on a reply...
