The "Settings" is suddenly part of the home page menu. How to remove it? I tried to "unpublish" however then the domain went down. So apparently it needs to be "published". Very strange that it turns up for every visitor to see. When I click on it live it takes me to the front page/home page. In preview mode from the editor mode it takes me to a page with "Lorem ipsum dolor sit amet, consectetur..."
Is 'Settings' one of your nodes? You can add a truefalse property to it called UmbracoNaviHide which if set to true should prevent it appearing (depending how your menu is coded)
"Settings" is showing in the menu for visitors. How to make it invisible for visitors
Thanks. I will dig into it! Not sure if it's the solution, though, since I don't know how my menu is coded. Will check with supplier :-)
