  • Anilal 1 post 71 karma points
    Mar 10, 2023 @ 18:14
    Anilal
    Nearest Location Based on ZipCode
    Hi Experts,
    In Umbraco, as part of the workflow task , if is possible to find the nearest store, if we pass the zip code?
    Is there any OOTB API call which we can make from Umbraco Or Is it possible to integrate with Google Maps ?
    In the Entries --below the Form-- > we can see the record with zip code captured from the website
    Kindly share your thoughts on this,
    Warm Regards Anilal KG
  • Huw Reddick 1929 posts 6697 karma points MVP 2x c-trib
    Mar 13, 2023 @ 09:02
    Huw Reddick
    Hi Anilal,
    There is no OOTB call you can use, so yes you will need to integrat google maps api or something similar.
