  • seanrock 262 posts 483 karma points
    Mar 15, 2023 @ 09:12
    seanrock
    Using claims in v11
    I'm trying to add some claims to the logged in member however I cannot get it working.
    There is another post re v9 however that solution doesn't work either, although I'm not using AD authentication, just straight forward member username/password.
    Has anyone used claims with member login in v11?
  • Joel Mandell 6 posts 78 karma points c-trib
    Jul 23, 2023 @ 00:34
    Joel Mandell
    This video might give you some hints on how to do it: https://youtu.be/aouFfym_7Zs
    It goes through adding a role specifically. But it should probably work by extending the demoed code to add claims to the newly instanced MemberIdentityUser (check the video for more information).
