  • Winnie 7 posts 97 karma points
    5 days ago
    Winnie
    How to iterate ID in a Block List for an Accordion - Umbraco 11
    So I'm using a Block List to create an Accordion. On principle, it works and renders correctly, but my problem is that my code requires a unique ID on the heading and the collapsed part to work. I'm using Bootstrap 4 and Umbraco 11.
    Here is the HTML for each accordion item in the partial view:
    <div class="card">
    <h3 class="card-header collapsed" id="heading1" href="#" data-toggle="collapse" data-target="#collapse1" aria-expanded="true" aria-controls="collapse1">@content.AccordionHeading</h3>
    <div id="collapse1" class="collapse" data-parent="#faq-accordion">
        <div class="card-body">
            @content.AccordionContent
    What I need is code that will automatically iterate the number in #heading and #collapse so that it does not open all cards at the same time.
    I was thinking the best way to do it would be with JavaScript. But I am not entirely sure.
  • Nik 1549 posts 6848 karma points MVP 5x c-trib
    5 days ago
    Nik
    Hi Winnie,
    Each element in the blocklist has a unique key against it. That is what I would typically use as the unique id.
    id="[email protected]"
    This saves any double iteration and ensure the header and content stay connected.
    Nik
    4 days ago
    Winnie
    I did not know that.
    I tired it, but it doesn't work. The error says "The name 'blocklistItem' does not exist in the current context". So I'm guessing I need to define it or something.
    Sorry, I'm very new to this.
    Here is the entire partial view:
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<Umbraco.Cms.Core.Models.Blocks.BlockListItem<ContentModels.Accordion>>;
    @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels;
    @using Umbraco.Cms.Core.Models;
        var content = (ContentModels.Accordion)Model.Content;
    <div class="card">
        <h3 class="card-header collapsed" href="#" data-toggle="collapse" data-target="#[email protected]" aria-expanded="true" aria-controls="[email protected]">@content.AccordionHeading</h3>
        <div id="[email protected]" class="collapse" data-parent="#faq-accordion">
    </div><!-- card end -->
  • Huw Reddick 1185 posts 4042 karma points c-trib
    4 days ago
    Huw Reddick
    looking at your code, try @content.Key
    4 days ago
    Winnie
    That was the only one I had not tried. Thanks.
