  • Claushingebjerg 927 posts 2530 karma points
    3 days ago
    Claushingebjerg
    problem getting animateOnScroll package to work
    I'm messing around with a V8 site, where there is a package installed called Our.Umbraco.AnimateOnScroll by Dennis Öhman.
    installation and setup foes fine, but when i try to render the output using the supplied code from the docs (adjusted to work with block list),
    <section @(Model.Value<Our.Umbraco.AnimateOnScroll.Models.Animation>("animate").ToHtml())>Animated section</<section>
    i get this error
    Compiler Error Message: CS0234: The type or namespace name 'AnimateOnScroll' does not exist in the namespace 'Our.Umbraco' (are you missing an assembly reference?)
    How do i fix this?
