  • Riki 1 post 71 karma points
    Mar 21, 2023 @ 09:18
    Riki
    umbraco Load balncing
    Hi we use umbraco 7.4.5 in our site we have 1 master server and 1 child server in different machines. I tried to config servers list like your documentation :
    <servers>
              <server serverName="{my master ip address}">{my master site name}</server>
              <server serverName="{my child ip address}">{my child site name}</server>
    </servers>
    but in my DB in the servers table the lastmodifieddate are not update and changes in umbraco not updates in my site correctly
  • Marc Goodson 2155 posts 14408 karma points MVP 9x c-trib
    Mar 21, 2023 @ 16:50
    Marc Goodson
    Hi Riki
    There are two approaches to Load balancing Umbraco in Version 7.
    The Legacy/Traditional way for V7.3 and below, where you configure servers in a
    https://our.umbraco.com/Documentation/Fundamentals/Setup/Server-Setup/Load-Balancing/traditional
    Listing the
    And there is a new approach introduced in 7.3 called 'Flexible Load Balancing' - https://our.umbraco.com/Documentation/Fundamentals/Setup/Server-Setup/Load-Balancing/
    Here the sites use a shared database to pass publishing instructions, so there is no need to configure Servers IP Addresses they do not communicate directly with each other, they just work off of the database table.
    As long as you have distributedCalls set to False, then if two Umbraco instances are sharing a database, Flexible Load Balancing will automatically try to work!
    There are some gotchas if you are using Azure Web Applications - but the article above links off to the necessary tweaks for those cloud environments.
    So with your Servers XML that you have posted, it makes me think you might be following the wrong documentation, eg the old approach, and expecting it to update the servers table (the new flexible approach!)
    regards
    Marc
