  • Dean 13 posts 123 karma points
    Mar 28, 2023 @ 20:57
    Dean
    Strongly typed model
    I've created a new class Library and moved all the models into it using the model builder and configuring the JSON file to move it to an external class library using Umbraco 10 and .Net 6.
    In my website project (Umbraco 10) I reference the class library (called Umbraco.Models).
    In my template (razor) how should I access the page/Doc type created? When I write
    UmbracoViewPage
    Models does not exist (I've added project reference). ContentModels.Home does exist?
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Mar 29, 2023 @ 07:39
    Huw Reddick
    Hi Dean,
    You should just be able to do
    @inherits UmbracoViewPage<Home>
    Mar 29, 2023 @ 09:32
    Dean
    Interestingly that worked!
    Maybe I misunderstood something here but I was trying a fully qualified name.
    This worked!
    But this didn't
    @inherits UmbracoViewPage<Umbraco.Models.Home>
    My models sit in a separate class library (so Home is a class declared as Home.generated.cs.
    When I hover over the code you supplied that works, I notice Home is Umbraco.CMS.Web.Common.PublishedModels.Home
    So is this mapping to the same object or in a polite way did you forget I mentioned my models are in a separate class library?
    Cheers
    Mar 29, 2023 @ 10:37
    Huw Reddick
    it will still belong to Umbraco.CMS.Web.Common.PublishedModels unless you change the namespace in the modelsbuilder settings "ModelsNamespace"
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Mar 29, 2023 @ 12:37
    Nik
    Hi Dean,
    As Huw says,
    The models are being generated in your own class library, that is correct, but unless you use the setting to set the models namespace they will still be using the default namespace of Umbraco.CMS.Web.Common.PublishedModels.
    https://docs.umbraco.com/umbraco-cms/reference/configuration/modelsbuildersettings
    The setting you need if you want to change their namespace is the "ModelsNamespace" property.
    Nik
    Mar 29, 2023 @ 13:43
    Dean
    No thanks Nik, they can remain in the same library/naming convention but I was confused thinking my class library isn't working the way it's supposed to but you guys have explained that well.
    So even though it's in a separate library I can continue to use the same path which is nice.
