  • Pieter Vanderheyden 11 posts 91 karma points
    Mar 30, 2023 @ 11:49
    Pieter Vanderheyden
    Save and preview not working for Safari
    I've gotten a complaint form a customer that the 'save and preview' button is not working on Safari. Here are the specifics: - Safari 16.3 (18614.4.6.1.6) - macOS Ventura 13.2.1 (Chip: M1) - Umbraco 11.1.0
    The problem: When clicking 'Save and preview', the item is saved but no preview window pops up. Also no error is given. On a macbook Air it gives the same issue. Older versions of Umbraco (tested on Umbraco 8.11.1 with the same OS and browser) do work as expected. So no issue there.
    I can't find anything about a fix in the release notes of a higher version and I also can't find any bug report on it. Unfortunately, I don't have the tools to check it myself as I only have MS Windows systems.
    Has anyone else come across this problem and/or could someone with these (or similar) specs try and reproduce the problem?
    Thanks for your help.
  • Paul Seal 524 posts 2890 karma points MVP 7x c-trib
    Apr 04, 2023 @ 11:42
    Paul Seal
    Hi Pieter
    I was expecting to look up the requirements for Umbraco and tell you that it doesn't support that version of Safari but I was wrong.
    I see you have raised an issue in GitHub.
    Here are the requirements if anyone is interested.
    And here is the Safari Version History
    Sorry I couldn't help on this one.
    Paul
    Apr 04, 2023 @ 11:47
    Pieter Vanderheyden
    Hi Paul
    I have to admit, I was also surprised to find Safari in the supported browsers list.
    Thanks for your reply and trying to help.
