  • Joao Pinto 13 posts 34 karma points
    Apr 11, 2023 @ 15:59
    Joao Pinto
    U10 - Blob storage for media very slow
    Recently I migrated a website from v8 to V10 and I'm facing performance issues in response time when accessing /media/ items (hosted on blob storage)
    With Umbraco V8 the avg response time for media items was under 100ms With Umbraco V10 the avg response time is between 1 to 2 seconds, sometimes it takes up to 30 seconds to load an image.
    The website is hosted in Azure and using Blob storage (standard 2) for media items.
    On UmbracoV8 it used Blob storage for media storage, BUT the cached items (crops) were hosted in the local storage of the App Service instead.
    With Umbraco V10 both media and cache are stored in blob storage.
    The website has many media items, here the numbers: 47.3k items in media folder 87.6k items in cache folder
    Does anyone have experience with websites that have such a big media storage on azure? Any performance issues?
  • Stuart Paterson 58 posts 229 karma points
    May 30, 2023 @ 15:43
    Stuart Paterson
    Joao,
    Just wondering if you had found the reason for this outside of this community post as I think I might be seeing a similar scenario.
    Thanks, Stuart
    May 30, 2023 @ 16:13
    Joao Pinto
    No reason and no solution found so far. We now configured the website to use local storage for crops cache and use blob storage only for media storage. But media requests are still very slow some times. The next thing we'll try is to delete unused medias to clean up the blob storage, maybe with less items it will get faster
  • fatmazayed 41 posts 123 karma points
    Jun 08, 2023 @ 09:17
    fatmazayed
    i have the same issue too
  • Sander van de Pas 74 posts 147 karma points
    Sep 22, 2023 @ 11:14
    Sander van de Pas
    Is there a solution for this issue already?
    We ran into the same problem.
    Grtz Sander
  • Garðar Þorsteinsson 119 posts 566 karma points
    Mar 19, 2024 @ 14:28
    Garðar Þorsteinsson
    After moving from Umbraco 8 to 10+ on multiple projects we are experience similar issues.
    Does not matter if the cache is on local or blob storage.
    We are seeing at random images taking from 1sec to 40sec to load.
    If we disable the blob storage package and use everything by default locally the issue goes away.
    This is having a major performance issues on many projects.
  • Erik Eelman 82 posts 322 karma points
    Jun 27, 2024 @ 13:43
    Erik Eelman
    We are experiencing the same issues. Does someone has a fix or workaround for this after all this time?
  • Alan Draper 57 posts 141 karma points
    Nov 20, 2024 @ 00:22
    Alan Draper
    Did you hear anything back? I'm getting the same problem.
  • jerin-ose 11 posts 32 karma points
    Nov 20, 2024 @ 04:49
    jerin-ose
    I have used a CDN to load the image, but I haven't yet checked how much time it takes. I will look into it and get back to you.
    Nov 20, 2024 @ 09:19
    Erik Eelman
    No, i didn't get any response. We've found out that the issue is most likely caused by the Umbraco.StorageProviders.AzureBlob package since it is using IFileProvider and this doesn't allow for async calls. And this might cause waiting requests if you get to many at once.
    Ronald made a draft PR some time ago for this: https://github.com/umbraco/Umbraco.StorageProviders/pull/26
    And some more info i found about this: https://procodeguide.com/asp-net-core/scale-aspnet-core-application-thread/
    Its not pretty, but for now what seems to help our website is to increase the minimal allowed threads in de program.cs:
    ServicePointManager.DefaultConnectionLimit = 100;
    ThreadPool.SetMinThreads(100, 100);
  • Mathias Poulsen 2 posts 72 karma points
    Feb 19, 2025 @ 10:48
    Mathias Poulsen
    I am getting the same issue in Umbraco 15.
    Images are taking up to 12 seconds to load, and they are all loading in at the same time when they are done loading.
    What is the cause behind this delay?
    Our hosting model is pretty straight forward.
    Umbraco 15 is hosted on a virtual machine, we have implemented the native Azure Blob provider and we have both files and cached files in Blob containers.
    Is it possible to get a hold of Umbraco to make suggestions at this point?
    Feb 20, 2025 @ 13:33
    Erik Eelman
    The draft PR for the storage provider doesn't seem to be active at the moment. I've asked if the are plans on updating the package. Hope this helps.
    In your specific use case, since your are hosting on a VM you might not need the Azure Blob provider. Did you try using the media from file system?
    Feb 20, 2025 @ 13:45
    Mathias Poulsen
    @erik eelman:
    We could, but the reason behind using Blob storage to begin with was to get the flexibility of scaling, because we are currently not sure of how big the media library can grow to potentially.
    Its easier to scale and more cost effective to have all media stored in Blob storage.
    Also in the article https://docs.umbraco.com/umbraco-cms/extending/filesystemproviders/azure-blob-storage they are stating this:
    Having your site's media in Azure Blob Storage can help your deployments complete more quickly. This has the potential to positively affect site performance, as the ImageSharp cache is moved to Azure Blob Storage.
