  • Jason D 75 posts 247 karma points
    Apr 11, 2023 @ 18:35
    Jason D
    Error: Implicit conversion from data type nvarchar to varbinary(max) is not allowed.
    When trying to rename a document type (or really just saving an update to a document type in general), I get this error. I'm not sure how to solve it, and I haven't changed any schema with the database.
    Implicit conversion from data type nvarchar to varbinary(max) is not allowed. Use the CONVERT function to run this query.
    Exception Details
    System.Data.SqlClient.SqlException: Implicit conversion from data type nvarchar to varbinary(max) is not allowed. Use the CONVERT function to run this query.
    Stacktrace
    at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
       at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
       at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
       at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func) in D:\a\1\s\src\Umbraco.Core\Persistence\FaultHandling\RetryPolicy.cs:line 172
       at Umbraco.Core.Persistence.NPocoDatabaseExtensions.BulkInsertRecordsWithCommands[T](IUmbracoDatabase database, T[] records) in D:\a\1\s\src\Umbraco.Core\Persistence\NPocoDatabaseExtensions-Bulk.cs:line 107
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.RebuildContentDbCacheLocked(IContentCacheDataSerializer serializer, IScope scope, Int32 groupSize, IEnumerable`1 contentTypeIds) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 1550
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.RebuildContentDbCache(Int32 groupSize, IEnumerable`1 contentTypeIds) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 1488
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.OnContentTypeRefreshedEntity(IContentTypeService sender, EventArgs args) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 1321
       at Umbraco.Core.Services.Implement.ContentTypeServiceBase`3.Save(TItem item, Int32 userId) in D:\a\1\s\src\Umbraco.Core\Services\Implement\ContentTypeServiceBaseOfTRepositoryTItemTService.cs:line 439
       at Umbraco.Web.Editors.ContentTypeControllerBase`1.PerformPostSave[TContentTypeDisplay,TContentTypeSave,TPropertyType](TContentTypeSave contentTypeSave, Func`2 getContentType, Action`1 saveContentType, Action`1 beforeCreateNew) in D:\a\1\s\src\Umbraco.Web\Editors\ContentTypeControllerBase.cs:line 297
       at Umbraco.Web.Editors.ContentTypeController.PostSave(DocumentTypeSave contentTypeSave) in D:\a\1\s\src\Umbraco.Web\Editors\ContentTypeController.cs:line 298
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
       at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
       at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
  • Nicholas Westby 2054 posts 7104 karma points c-trib
    Apr 12, 2023 @ 01:21
    Apr 19, 2023 @ 22:49
    Jason D
    That explains why this only happens in local development (2022), as our two other instances are 2019.
    Thanks!
  • Justin Neville 24 posts 198 karma points c-trib
    Apr 26, 2023 @ 20:24
    Justin Neville
    FYI - I ran across this issue this week and have put in a PR with details in case anyone else comes across this:
    https://github.com/umbraco/Umbraco-CMS/pull/14173
  • WebTeam 5 posts 85 karma points
    Jun 21, 2023 @ 07:11
    WebTeam
    Thanks for the reply guys. I will have a look at your recommendations
