  • CampanaP 4 posts 54 karma points
    Apr 14, 2023 @ 13:56
    CampanaP
    Umbraco 8 - Redirect upper case Url
    Hello everyone, I am asking for your support on this issue. I have tried to set up a rule on my website which checks that there are capital letters in the url so that I can perform a redirect with the url in lower case.
    On the website side there is no problem, but with the Umbraco BackOffice I have experienced some malfunctions, for example the Homepage page is no longer displayed when I try to access the BackOffice.
    I think the reason is that Umbraco's BackOffice makes calls with addresses containing capital letters. I have tried excluding urls containing Umbraco, are there any other checks I can do to exclude all calls made from the BackOffice?
    Thank you all very much for your availability.
  • Huw Reddick 1929 posts 6697 karma points MVP 2x c-trib
    Apr 14, 2023 @ 14:36
    Huw Reddick
    What is your requirement for doing this?
    Apr 14, 2023 @ 14:38
    Huw Reddick
    The back office will be making calls to App_Plugins folder
    Apr 18, 2023 @ 07:46
    CampanaP
    Hi, thanks for the input, but it was not enough to solve. In order to get it working I had to go and remove all the calls that went to DependencyHandler.axd which, as I understand from googling, is used to manage dependencies for the JS and CSS resources in the BackOffice.
