  • Ewa Nikodem 2 posts 72 karma points
    Apr 18, 2023 @ 13:55
    Ewa Nikodem
    Appearing div class='container'
    Hello everyone. I have a small problem. Since upgrading from Umbraco 8.5.5 to 8.18.4 a div class='container' has been appearing on few of our content pages.
    It appears as a text on the website. enter image description here
    and this is how it looks when you click inspect:enter image description here
    We searched carefully and no, it's nowhere in our code. So it seems like an Umbraco issue. This div class='container' only appears in front of text that was edited with rich text editor. Has anyone struggled with the same problem?
    Thank you for the response.
  • Lindow 154 posts 1301 karma points
    Apr 18, 2023 @ 13:58
    Lindow
    Heya Ewa
    Since it's an RTE, I believe that this specific part of the code is in the RTE.
    Try finding one of the RTE properties in the backoffice and click on the view source code icon which should open the code editor for the property :)
    Apr 18, 2023 @ 16:48
    Ewa Nikodem
    Thank you, I will try that .
  • Sander Los 27 posts 160 karma points
    Apr 18, 2023 @ 15:50
    Sander Los
    We used to have a similar issue in the past. I believe it was because of htmlif that did not work anymore after an upgrade.
